clear counters policy
Description
Clears policy rule usage statistics.
Syntax Description
Default
N/A.
Usage Guidelines
This command resets the counters on each rule to zero and clears the rule usage.
To see a list of used rules, use the port-hit option with the command show policy rule port-hit {data} {detail} {wide}.
The following example clears policy rule usage statistics:
# clear counters policy
# show policy rule port-hit
No entries found.
This command was first available in ExtremeXOS 30.2.
Platform Availability
